Time Before: 0.00847 seconds
Time After: 0.01175 seconds
Time Taken: 0.00328 seconds
Time Before: 0.01185 seconds
Time After: 0.01231 seconds
Time Before: 0.01258 seconds
Time After: 0.01271 seconds
Time Before: 0.01348 seconds
Time After: 0.01620 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01278 seconds
Time After: 0.02028 seconds
Time Taken: 0.00751 seconds
Time Before: 0.02545 seconds
Time After: 0.02589 seconds
Time Before: 0.02762 seconds
Time After: 0.02887 seconds
Time Before: 0.02477 seconds
Time After: 0.02912 seconds
Time Taken: 0.00435 seconds
Time Before: 0.04774 seconds
Time After: 0.04792 seconds
Time Before: 0.05826 seconds
Time After: 0.05949 seconds
End call of global.php: 0.061973094940186
Time Before: 0.06508 seconds
Time After: 0.06523 seconds
Time Before: 0.06794 seconds
Time After: 0.06941 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115322'
Time Before: 0.08525 seconds
Time After: 0.08551 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.084172964096069 seconds with 9 queries, spending 0.0082674026489258 doing MySQL queries and 0.075905561447144 doing PHP things.
