Time Before: 0.00186 seconds
Time After: 0.00250 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00260 seconds
Time After: 0.00303 seconds
Time Before: 0.00327 seconds
Time After: 0.00342 seconds
Time Before: 0.00429 seconds
Time After: 0.00722 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00349 seconds
Time After: 0.01149 seconds
Time Taken: 0.00800 seconds
Time Before: 0.01393 seconds
Time After: 0.01435 seconds
Time Before: 0.01811 seconds
Time After: 0.01964 seconds
Time Taken: 0.00153 seconds
Time Before: 0.01297 seconds
Time After: 0.01986 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02550 seconds
Time After: 0.02563 seconds
Time Before: 0.02802 seconds
Time After: 0.02925 seconds
End call of global.php: 0.031029939651489
Time Before: 0.03325 seconds
Time After: 0.03345 seconds
Time Before: 0.03628 seconds
Time After: 0.03778 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1784862048, location = '/forums/private.php?do=newpm&explain=1&u=115344'
Time Before: 0.05523 seconds
Time After: 0.05566 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.053725957870483 seconds with 9 queries, spending 0.0089297294616699 doing MySQL queries and 0.044796228408813 doing PHP things.
