Time Before: 0.00770 seconds
Time After: 0.01049 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01058 seconds
Time After: 0.01096 seconds
Time Before: 0.01118 seconds
Time After: 0.01130 seconds
Time Before: 0.01206 seconds
Time After: 0.01426 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01137 seconds
Time After: 0.01869 seconds
Time Taken: 0.00732 seconds
Time Before: 0.02215 seconds
Time After: 0.02248 seconds
Time Before: 0.02508 seconds
Time After: 0.02624 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02151 seconds
Time After: 0.02644 seconds
Time Taken: 0.00493 seconds
Time Before: 0.04505 seconds
Time After: 0.04518 seconds
Time Before: 0.05433 seconds
Time After: 0.05555 seconds
End call of global.php: 0.057296991348267
Time Before: 0.06076 seconds
Time After: 0.06088 seconds
Time Before: 0.06276 seconds
Time After: 0.06416 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785334910, location = '/forums/private.php?do=newpm&explain=1&u=115370', badlocation = 1
Time Before: 0.07819 seconds
Time After: 0.07842 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.077283143997192 seconds with 9 queries, spending 0.0072858333587646 doing MySQL queries and 0.069997310638428 doing PHP things.
