Time Before: 0.02391 seconds
Time After: 0.03089 seconds
Time Taken: 0.00698 seconds
Time Before: 0.03100 seconds
Time After: 0.03150 seconds
Time Before: 0.03179 seconds
Time After: 0.03196 seconds
Time Before: 0.03281 seconds
Time After: 0.03534 seconds
Time Taken: 0.00253 seconds
Time Before: 0.03204 seconds
Time After: 0.03981 seconds
Time Taken: 0.00777 seconds
Time Before: 0.05049 seconds
Time After: 0.05089 seconds
Time Before: 0.05341 seconds
Time After: 0.05467 seconds
Time Before: 0.04977 seconds
Time After: 0.05487 seconds
Time Taken: 0.00511 seconds
Time Before: 0.09596 seconds
Time After: 0.09615 seconds
Time Before: 0.11369 seconds
Time After: 0.11493 seconds
Time Before: 0.12393 seconds
Time After: 0.12416 seconds
Time Before: 0.12679 seconds
Time After: 0.12825 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115387' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.14988 seconds
Time After: 0.15019 seconds
