Time Before: 0.02685 seconds
Time After: 0.03589 seconds
Time Taken: 0.00904 seconds
Time Before: 0.03596 seconds
Time After: 0.03640 seconds
Time Before: 0.03666 seconds
Time After: 0.03684 seconds
Time Before: 0.03759 seconds
Time After: 0.03997 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03692 seconds
Time After: 0.04480 seconds
Time Taken: 0.00788 seconds
Time Before: 0.05313 seconds
Time After: 0.05358 seconds
Time Before: 0.05602 seconds
Time After: 0.05721 seconds
Time Before: 0.05243 seconds
Time After: 0.05746 seconds
Time Taken: 0.00503 seconds
Time Before: 0.11047 seconds
Time After: 0.11061 seconds
Time Before: 0.12841 seconds
Time After: 0.12987 seconds
End call of global.php: 0.13207602500916
Time Before: 0.14467 seconds
Time After: 0.14481 seconds
Time Before: 0.14775 seconds
Time After: 0.14921 seconds
SET lastactivity = 1780663321, location = '/forums/private.php?do=newpm&explain=1&u=115421', badlocation = 1
Time Before: 0.17052 seconds
Time After: 0.18004 seconds
Time Taken: 0.00952 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.1693799495697 seconds with 9 queries, spending 0.017355918884277 doing MySQL queries and 0.15202403068542 doing PHP things.
