Time Before: 0.00155 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00241 seconds
Time Before: 0.00259 seconds
Time After: 0.00269 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00338 seconds
Time After: 0.00565 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00274 seconds
Time After: 0.01021 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01222 seconds
Time After: 0.01264 seconds
Time Before: 0.01578 seconds
Time After: 0.01698 seconds
Time Before: 0.01137 seconds
Time After: 0.01723 seconds
Time Taken: 0.00586 seconds
Time Before: 0.02293 seconds
Time After: 0.02305 seconds
Time Before: 0.02503 seconds
Time After: 0.02625 seconds
End call of global.php: 0.028134107589722
Time Before: 0.02952 seconds
Time After: 0.02965 seconds
Time Before: 0.03226 seconds
Time After: 0.03375 seconds
SET lastactivity = 1785299249, location = '/forums/private.php?do=newpm&explain=1&u=115439', badlocation = 1
Time Before: 0.04695 seconds
Time After: 0.04724 seconds
Page generated in 0.046019077301025 seconds with 9 queries, spending 0.0075879096984863 doing MySQL queries and 0.038431167602539 doing PHP things.
