Time Before: 0.00181 seconds
Time After: 0.00227 seconds
Time Before: 0.00234 seconds
Time After: 0.00297 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00319 seconds
Time After: 0.00350 seconds
Time Before: 0.00423 seconds
Time After: 0.00674 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00355 seconds
Time After: 0.01019 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01204 seconds
Time After: 0.01240 seconds
Time Before: 0.01481 seconds
Time After: 0.01597 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01149 seconds
Time After: 0.01615 seconds
Time Taken: 0.00466 seconds
Time Before: 0.02362 seconds
Time After: 0.02379 seconds
Time Before: 0.02598 seconds
Time After: 0.02723 seconds
End call of global.php: 0.028944969177246
Time Before: 0.03029 seconds
Time After: 0.03043 seconds
Time Before: 0.03248 seconds
Time After: 0.03413 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115453', badlocation = 1
Time Before: 0.04659 seconds
Time After: 0.04696 seconds
Page generated in 0.045666933059692 seconds with 9 queries, spending 0.0085420608520508 doing MySQL queries and 0.037124872207642 doing PHP things.
