Time Before: 0.00555 seconds
Time After: 0.00774 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00781 seconds
Time After: 0.00827 seconds
Time Before: 0.00852 seconds
Time After: 0.00865 seconds
Time Before: 0.00944 seconds
Time After: 0.01248 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00872 seconds
Time After: 0.01748 seconds
Time Taken: 0.00876 seconds
Time Before: 0.02174 seconds
Time After: 0.02213 seconds
Time Before: 0.02470 seconds
Time After: 0.02590 seconds
Time Before: 0.02104 seconds
Time After: 0.02613 seconds
Time Taken: 0.00510 seconds
Time Before: 0.03951 seconds
Time After: 0.03971 seconds
Time Before: 0.04552 seconds
Time After: 0.04680 seconds
End call of global.php: 0.049045085906982
Time Before: 0.05315 seconds
Time After: 0.05343 seconds
Time Before: 0.05638 seconds
Time After: 0.05789 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1776478037, location = '/forums/private.php?do=newpm&explain=1&u=115458'
Time Before: 0.07872 seconds
Time After: 0.07906 seconds
Page generated in 0.077221155166626 seconds with 9 queries, spending 0.0088307857513428 doing MySQL queries and 0.068390369415283 doing PHP things.
