Time Before: 0.00151 seconds
Time After: 0.00216 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00225 seconds
Time After: 0.00443 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00516 seconds
Time After: 0.00555 seconds
Time Before: 0.00638 seconds
Time After: 0.00872 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00563 seconds
Time After: 0.01433 seconds
Time Taken: 0.00870 seconds
Time Before: 0.01734 seconds
Time After: 0.01773 seconds
Time Before: 0.02037 seconds
Time After: 0.02216 seconds
Time Taken: 0.00179 seconds
Time Before: 0.01653 seconds
Time After: 0.02248 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02908 seconds
Time After: 0.02928 seconds
Time Before: 0.03111 seconds
Time After: 0.03352 seconds
Time Taken: 0.00240 seconds
End call of global.php: 0.035309076309204
Time Before: 0.03657 seconds
Time After: 0.03675 seconds
Time Before: 0.03970 seconds
Time After: 0.04158 seconds
Time Taken: 0.00189 seconds
SET lastactivity = 1788887186, location = '/forums/private.php?do=newpm&explain=1&u=115520'
Time Before: 0.05524 seconds
Time After: 0.05586 seconds
Time Taken: 0.00062 seconds
Page generated in 0.054315090179443 seconds with 9 queries, spending 0.012393474578857 doing MySQL queries and 0.041921615600586 doing PHP things.
