Time Before: 0.00820 seconds
Time After: 0.01227 seconds
Time Taken: 0.00407 seconds
Time Before: 0.01239 seconds
Time After: 0.01284 seconds
Time Before: 0.01332 seconds
Time After: 0.01346 seconds
Time Before: 0.01447 seconds
Time After: 0.01667 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01355 seconds
Time After: 0.02202 seconds
Time Taken: 0.00847 seconds
Time Before: 0.02744 seconds
Time After: 0.02787 seconds
Time Before: 0.03117 seconds
Time After: 0.03238 seconds
Time Before: 0.02660 seconds
Time After: 0.03259 seconds
Time Taken: 0.00599 seconds
Time Before: 0.04657 seconds
Time After: 0.04672 seconds
Time Before: 0.05855 seconds
Time After: 0.05982 seconds
Time Before: 0.06636 seconds
Time After: 0.06652 seconds
Time Before: 0.06963 seconds
Time After: 0.07182 seconds
Time Taken: 0.00219 seconds
UPDATE session SET lastactivity = 1788952056, location = '/forums/private.php?do=newpm&explain=1&u=115540' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.08929 seconds
Time After: 0.08972 seconds
