Time Before: 0.00559 seconds
Time After: 0.00717 seconds
Time Taken: 0.00157 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.00728 seconds
Time After: 0.00778 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.00803 seconds
Time After: 0.00853 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.00951 seconds
Time After: 0.01187 seconds
Time Taken: 0.00236 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.00860 seconds
Time After: 0.01730 seconds
Time Taken: 0.00870 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.02155 seconds
Time After: 0.02206 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.02475 seconds
Time After: 0.02613 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.02077 seconds
Time After: 0.02633 seconds
Time Taken: 0.00556 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.04052 seconds
Time After: 0.04068 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.04764 seconds
Time After: 0.04893 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
Time Before: 0.05395 seconds
Time After: 0.05414 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.05640 seconds
Time After: 0.05786 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
UPDATE session SET lastactivity = 1788916908, location = '/forums/private.php?do=newpm&explain=1&u=115554' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.07571 seconds
Time After: 0.07609 seconds
Memory Before: 4,295.383 KB
Memory After: 4,295.609 KB
