Time Before: 0.02465 seconds
Time After: 0.03301 seconds
Time Taken: 0.00836 seconds
Time Before: 0.03313 seconds
Time After: 0.03363 seconds
Time Before: 0.03393 seconds
Time After: 0.03409 seconds
Time Before: 0.03498 seconds
Time After: 0.03724 seconds
Time Taken: 0.00226 seconds
Time Before: 0.03417 seconds
Time After: 0.04150 seconds
Time Taken: 0.00732 seconds
Time Before: 0.05098 seconds
Time After: 0.05139 seconds
Time Before: 0.05394 seconds
Time After: 0.05516 seconds
Time Before: 0.05019 seconds
Time After: 0.05541 seconds
Time Taken: 0.00522 seconds
Time Before: 0.10001 seconds
Time After: 0.10024 seconds
Time Before: 0.11792 seconds
Time After: 0.11917 seconds
End call of global.php: 0.12136292457581
Time Before: 0.13425 seconds
Time After: 0.13441 seconds
Time Before: 0.13697 seconds
Time After: 0.13850 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115608'
Time Before: 0.16037 seconds
Time After: 0.16062 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.15935707092285 seconds with 9 queries, spending 0.0079739093780518 doing MySQL queries and 0.1513831615448 doing PHP things.
