Time Before: 0.00137 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00240 seconds
Time Before: 0.00267 seconds
Time After: 0.00282 seconds
Time Before: 0.00371 seconds
Time After: 0.00679 seconds
Time Taken: 0.00308 seconds
Time Before: 0.00289 seconds
Time After: 0.01026 seconds
Time Taken: 0.00737 seconds
Time Before: 0.01200 seconds
Time After: 0.01220 seconds
Time Before: 0.01467 seconds
Time After: 0.01601 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01146 seconds
Time After: 0.01621 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02179 seconds
Time After: 0.02193 seconds
Time Before: 0.02385 seconds
Time After: 0.02514 seconds
End call of global.php: 0.026893138885498
Time Before: 0.02810 seconds
Time After: 0.02824 seconds
Time Before: 0.03039 seconds
Time After: 0.03197 seconds
Time Taken: 0.00158 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115655'
Time Before: 0.04458 seconds
Time After: 0.04494 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.043647050857544 seconds with 9 queries, spending 0.0086920261383057 doing MySQL queries and 0.034955024719238 doing PHP things.
