Time Before: 0.02704 seconds
Time After: 0.03614 seconds
Time Taken: 0.00910 seconds
Time Before: 0.03624 seconds
Time After: 0.03668 seconds
Time Before: 0.03691 seconds
Time After: 0.03702 seconds
Time Before: 0.03774 seconds
Time After: 0.04023 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03707 seconds
Time After: 0.04427 seconds
Time Taken: 0.00720 seconds
Time Before: 0.05493 seconds
Time After: 0.05515 seconds
Time Before: 0.05877 seconds
Time After: 0.05996 seconds
Time Before: 0.05425 seconds
Time After: 0.06018 seconds
Time Taken: 0.00593 seconds
Time Before: 0.09937 seconds
Time After: 0.09949 seconds
Time Before: 0.11785 seconds
Time After: 0.11928 seconds
Time Before: 0.13772 seconds
Time After: 0.13786 seconds
Time Before: 0.14063 seconds
Time After: 0.14237 seconds
Time Taken: 0.00174 seconds
UPDATE session SET lastactivity = 1777078911, location = '/forums/private.php?do=newpm&explain=1&u=115716', badlocation = 1 WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.16302 seconds
Time After: 0.16341 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
