Time Before: 0.00906 seconds
Time After: 0.01236 seconds
Time Taken: 0.00331 seconds
Time Before: 0.01245 seconds
Time After: 0.01296 seconds
Time Before: 0.01325 seconds
Time After: 0.01340 seconds
Time Before: 0.01423 seconds
Time After: 0.01661 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01348 seconds
Time After: 0.02157 seconds
Time Taken: 0.00809 seconds
Time Before: 0.02706 seconds
Time After: 0.02744 seconds
Time Before: 0.03010 seconds
Time After: 0.03131 seconds
Time Before: 0.02604 seconds
Time After: 0.03156 seconds
Time Taken: 0.00553 seconds
Time Before: 0.05006 seconds
Time After: 0.05022 seconds
Time Before: 0.05983 seconds
Time After: 0.06107 seconds
Time Before: 0.06757 seconds
Time After: 0.06775 seconds
Time Before: 0.07042 seconds
Time After: 0.07187 seconds
UPDATE session SET lastactivity = 1783216259, location = '/forums/private.php?do=newpm&explain=1&u=115737', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.08928 seconds
Time After: 0.08971 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
