Time Before: 0.02663 seconds
Time After: 0.03493 seconds
Time Taken: 0.00830 seconds
Time Before: 0.03504 seconds
Time After: 0.03576 seconds
Time Taken: 0.00072 seconds
Time Before: 0.03598 seconds
Time After: 0.03614 seconds
Time Before: 0.03706 seconds
Time After: 0.03903 seconds
Time Taken: 0.00196 seconds
Time Before: 0.03622 seconds
Time After: 0.04304 seconds
Time Taken: 0.00682 seconds
Time Before: 0.05026 seconds
Time After: 0.05091 seconds
Time Taken: 0.00065 seconds
Time Before: 0.05349 seconds
Time After: 0.05544 seconds
Time Taken: 0.00195 seconds
Time Before: 0.04963 seconds
Time After: 0.05564 seconds
Time Taken: 0.00601 seconds
Time Before: 0.08700 seconds
Time After: 0.08711 seconds
Time Before: 0.10859 seconds
Time After: 0.10989 seconds
End call of global.php: 0.11193799972534
Time Before: 0.12094 seconds
Time After: 0.12113 seconds
Time Before: 0.12351 seconds
Time After: 0.12494 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115749', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.14518 seconds
Time After: 0.14550 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.14415812492371 seconds with 9 queries, spending 0.0088117122650146 doing MySQL queries and 0.13534641265869 doing PHP things.
