Time Before: 0.00186 seconds
Time After: 0.00243 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00253 seconds
Time After: 0.00301 seconds
Time Before: 0.00324 seconds
Time After: 0.00337 seconds
Time Before: 0.00426 seconds
Time After: 0.00677 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00345 seconds
Time After: 0.01131 seconds
Time Taken: 0.00786 seconds
Time Before: 0.01369 seconds
Time After: 0.01410 seconds
Time Before: 0.01672 seconds
Time After: 0.01854 seconds
Time Taken: 0.00182 seconds
Time Before: 0.01294 seconds
Time After: 0.01880 seconds
Time Taken: 0.00586 seconds
Time Before: 0.02555 seconds
Time After: 0.02568 seconds
Time Before: 0.02833 seconds
Time After: 0.02964 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03298 seconds
Time After: 0.03310 seconds
Time Before: 0.03516 seconds
Time After: 0.03660 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115750' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04993 seconds
Time After: 0.05040 seconds
