Time Before: 0.00135 seconds
Time After: 0.00192 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00199 seconds
Time After: 0.00255 seconds
Time Before: 0.00284 seconds
Time After: 0.00296 seconds
Time Before: 0.00366 seconds
Time After: 0.00615 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00301 seconds
Time After: 0.00952 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01169 seconds
Time After: 0.01210 seconds
Time Before: 0.01349 seconds
Time After: 0.01471 seconds
Time Before: 0.01105 seconds
Time After: 0.01488 seconds
Time Taken: 0.00384 seconds
Time Before: 0.02032 seconds
Time After: 0.02054 seconds
Time Before: 0.02275 seconds
Time After: 0.02404 seconds
Time Before: 0.02694 seconds
Time After: 0.02709 seconds
Time Before: 0.02901 seconds
Time After: 0.03045 seconds
UPDATE session SET lastactivity = 1780645477, location = '/forums/private.php?do=newpm&explain=1&u=115756', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04272 seconds
Time After: 0.04302 seconds
