Time Before: 0.02609 seconds
Time After: 0.03607 seconds
Time Taken: 0.00999 seconds
Time Before: 0.03617 seconds
Time After: 0.03661 seconds
Time Before: 0.03686 seconds
Time After: 0.03700 seconds
Time Before: 0.03784 seconds
Time After: 0.04017 seconds
Time Taken: 0.00233 seconds
Time Before: 0.03706 seconds
Time After: 0.04470 seconds
Time Taken: 0.00764 seconds
Time Before: 0.05376 seconds
Time After: 0.05403 seconds
Time Before: 0.05685 seconds
Time After: 0.05827 seconds
Time Before: 0.05300 seconds
Time After: 0.05846 seconds
Time Taken: 0.00546 seconds
Time Before: 0.10621 seconds
Time After: 0.10636 seconds
Time Before: 0.64619 seconds
Time After: 0.64831 seconds
Time Taken: 0.00212 seconds
End call of global.php: 0.65062594413757
Time Before: 0.65974 seconds
Time After: 0.65991 seconds
Time Before: 0.66288 seconds
Time After: 0.66467 seconds
Time Taken: 0.00179 seconds
SET lastactivity = 1776748730, location = '/forums/private.php?do=newpm&explain=1&u=115773', badlocation = 1
Time Before: 0.68887 seconds
Time After: 0.68916 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.68783092498779 seconds with 9 queries, spending 0.0091238021850586 doing MySQL queries and 0.67870712280273 doing PHP things.
