Time Before: 0.00148 seconds
Time After: 0.00221 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00231 seconds
Time After: 0.00287 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00311 seconds
Time After: 0.00321 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00391 seconds
Time After: 0.00641 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00326 seconds
Time After: 0.00985 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01164 seconds
Time After: 0.01199 seconds
Time Before: 0.01439 seconds
Time After: 0.01558 seconds
Time Before: 0.01110 seconds
Time After: 0.01575 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02083 seconds
Time After: 0.02099 seconds
Time Before: 0.02287 seconds
Time After: 0.02425 seconds
Time Taken: 0.00138 seconds
End call of global.php: 0.026711940765381
Time Before: 0.02809 seconds
Time After: 0.02825 seconds
Time Before: 0.03046 seconds
Time After: 0.03192 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115828', badlocation = 1
Time Before: 0.04417 seconds
Time After: 0.04442 seconds
Page generated in 0.043278932571411 seconds with 9 queries, spending 0.0081028938293457 doing MySQL queries and 0.035176038742065 doing PHP things.
