Time Before: 0.01752 seconds
Time After: 0.02192 seconds
Time Taken: 0.00441 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02204 seconds
Time After: 0.02261 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02292 seconds
Time After: 0.02307 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02385 seconds
Time After: 0.02641 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02314 seconds
Time After: 0.03113 seconds
Time Taken: 0.00799 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03841 seconds
Time After: 0.03878 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04121 seconds
Time After: 0.04244 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03761 seconds
Time After: 0.04270 seconds
Time Taken: 0.00509 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07265 seconds
Time After: 0.07284 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.16855 seconds
Time After: 0.16981 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.17208003997803
Time Before: 0.19685 seconds
Time After: 0.19707 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.20342 seconds
Time After: 0.20497 seconds
Time Taken: 0.00155 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773211650, location = '/forums/private.php?do=newpm&explain=1&u=115836', badlocation = 1
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.23026 seconds
Time After: 0.23055 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.22912812232971 seconds with 9 queries, spending 0.0083820819854736 doing MySQL queries and 0.22074604034424 doing PHP things.
