Time Before: 0.02761 seconds
Time After: 0.03824 seconds
Time Taken: 0.01063 seconds
Time Before: 0.03836 seconds
Time After: 0.03882 seconds
Time Before: 0.03905 seconds
Time After: 0.03924 seconds
Time Before: 0.04002 seconds
Time After: 0.04249 seconds
Time Taken: 0.00247 seconds
Time Before: 0.03931 seconds
Time After: 0.04654 seconds
Time Taken: 0.00723 seconds
Time Before: 0.05567 seconds
Time After: 0.05628 seconds
Time Taken: 0.00061 seconds
Time Before: 0.05875 seconds
Time After: 0.05999 seconds
Time Before: 0.05492 seconds
Time After: 0.06018 seconds
Time Taken: 0.00526 seconds
Time Before: 0.10307 seconds
Time After: 0.10324 seconds
Time Before: 0.11943 seconds
Time After: 0.12068 seconds
Time Before: 0.13123 seconds
Time After: 0.13138 seconds
Time Before: 0.13371 seconds
Time After: 0.13513 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115842', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.15499 seconds
Time After: 0.15529 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
