Time Before: 0.03035 seconds
Time After: 0.04336 seconds
Time Taken: 0.01302 seconds
Time Before: 0.04348 seconds
Time After: 0.04392 seconds
Time Before: 0.04417 seconds
Time After: 0.04426 seconds
Time Taken: 0.00010 seconds
Time Before: 0.04496 seconds
Time After: 0.04753 seconds
Time Taken: 0.00256 seconds
Time Before: 0.04433 seconds
Time After: 0.05167 seconds
Time Taken: 0.00734 seconds
Time Before: 0.06499 seconds
Time After: 0.06520 seconds
Time Before: 0.06648 seconds
Time After: 0.06796 seconds
Time Before: 0.06424 seconds
Time After: 0.06824 seconds
Time Taken: 0.00400 seconds
Time Before: 0.11667 seconds
Time After: 0.11680 seconds
Time Before: 0.13544 seconds
Time After: 0.13669 seconds
End call of global.php: 0.13929510116577
Time Before: 0.14745 seconds
Time After: 0.14764 seconds
Time Before: 0.15084 seconds
Time After: 0.15231 seconds
SET lastactivity = 1776705361, location = '/forums/private.php?do=newpm&explain=1&u=115859', badlocation = 1
Time Before: 0.17328 seconds
Time After: 0.17359 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.17221307754517 seconds with 9 queries, spending 0.0081286430358887 doing MySQL queries and 0.16408443450928 doing PHP things.
