Time Before: 0.03757 seconds
Time After: 0.04277 seconds
Time Taken: 0.00520 seconds
Time Before: 0.04287 seconds
Time After: 0.04374 seconds
Time Taken: 0.00087 seconds
Time Before: 0.04416 seconds
Time After: 0.04437 seconds
Time Before: 0.04535 seconds
Time After: 0.04794 seconds
Time Taken: 0.00260 seconds
Time Before: 0.04446 seconds
Time After: 0.05320 seconds
Time Taken: 0.00873 seconds
Memory After: 1,642.430 KB
Memory Used: 1,081.023 KB
Time Before: 0.06551 seconds
Time After: 0.06574 seconds
Memory Before: 2,137.359 KB
Memory After: 2,137.977 KB
Time Before: 0.06830 seconds
Time After: 0.06956 seconds
Memory Before: 2,149.422 KB
Memory After: 2,149.281 KB
Time Before: 0.06478 seconds
Time After: 0.06982 seconds
Time Taken: 0.00504 seconds
Memory Before: 2,129.539 KB
Memory After: 2,262.344 KB
Time Before: 0.12238 seconds
Time After: 0.12261 seconds
Memory Before: 2,815.859 KB
Memory After: 2,816.375 KB
Time Before: 0.13582 seconds
Time After: 0.13707 seconds
Memory Before: 2,904.055 KB
Memory After: 2,904.648 KB
End call of global.php: 0.13889503479004
Time Before: 0.14494 seconds
Time After: 0.14516 seconds
Memory Before: 3,540.836 KB
Memory After: 3,541.266 KB
Time Before: 0.14733 seconds
Time After: 0.14886 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,822.414 KB
Memory After: 3,824.102 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=115868', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.16719 seconds
Time After: 0.17728 seconds
Time Taken: 0.01010 seconds
Memory Before: 4,288.086 KB
Memory After: 4,288.313 KB
Page generated in 0.16599893569946 seconds with 9 queries, spending 0.018493175506592 doing MySQL queries and 0.14750576019287 doing PHP things.
