Time Before: 0.00147 seconds
Time After: 0.00207 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00215 seconds
Time After: 0.00261 seconds
Time Before: 0.00289 seconds
Time After: 0.00302 seconds
Time Before: 0.00399 seconds
Time After: 0.00652 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00311 seconds
Time After: 0.01133 seconds
Time Taken: 0.00822 seconds
Time Before: 0.01335 seconds
Time After: 0.01381 seconds
Time Before: 0.01696 seconds
Time After: 0.01818 seconds
Time Before: 0.01269 seconds
Time After: 0.01836 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02381 seconds
Time After: 0.02405 seconds
Time Before: 0.02586 seconds
Time After: 0.02707 seconds
End call of global.php: 0.028700113296509
Time Before: 0.03036 seconds
Time After: 0.03052 seconds
Time Before: 0.03376 seconds
Time After: 0.03518 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115895'
Time Before: 0.04761 seconds
Time After: 0.04800 seconds
Page generated in 0.046709060668945 seconds with 9 queries, spending 0.0082201957702637 doing MySQL queries and 0.038488864898682 doing PHP things.
