Time Before: 0.00157 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00253 seconds
Time Before: 0.00271 seconds
Time After: 0.00283 seconds
Time Before: 0.00354 seconds
Time After: 0.00604 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00288 seconds
Time After: 0.01006 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01198 seconds
Time After: 0.01236 seconds
Time Before: 0.01417 seconds
Time After: 0.01539 seconds
Time Before: 0.01132 seconds
Time After: 0.01564 seconds
Time Taken: 0.00432 seconds
Time Before: 0.02319 seconds
Time After: 0.02333 seconds
Time Before: 0.02572 seconds
Time After: 0.02696 seconds
End call of global.php: 0.028789043426514
Time Before: 0.03024 seconds
Time After: 0.03038 seconds
Time Before: 0.03245 seconds
Time After: 0.03388 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=115908', badlocation = 1
Time Before: 0.04790 seconds
Time After: 0.04818 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.046980857849121 seconds with 9 queries, spending 0.0078282356262207 doing MySQL queries and 0.0391526222229 doing PHP things.
