Time Before: 0.04384 seconds
Time After: 0.06172 seconds
Time Taken: 0.01787 seconds
Time Before: 0.06181 seconds
Time After: 0.06275 seconds
Time Taken: 0.00094 seconds
Time Before: 0.06310 seconds
Time After: 0.06325 seconds
Time Before: 0.06413 seconds
Time After: 0.06667 seconds
Time Taken: 0.00254 seconds
Time Before: 0.06333 seconds
Time After: 0.07184 seconds
Time Taken: 0.00851 seconds
Time Before: 0.08822 seconds
Time After: 0.08911 seconds
Time Taken: 0.00090 seconds
Time Before: 0.09172 seconds
Time After: 0.09294 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.08691 seconds
Time After: 0.09318 seconds
Time Taken: 0.00627 seconds
Memory After: 2,261.836 KB
Memory Used: 132.898 KB
Time Before: 0.16226 seconds
Time After: 0.16243 seconds
Memory Before: 2,815.383 KB
Memory After: 2,815.898 KB
Time Before: 0.20011 seconds
Time After: 0.20135 seconds
Memory Before: 2,903.578 KB
Memory After: 2,904.172 KB
Time Before: 0.21593 seconds
Time After: 0.21610 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.21863 seconds
Time After: 0.22010 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
UPDATE session SET lastactivity = 1788901323, location = '/forums/private.php?do=newpm&explain=1&u=115948', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.23836 seconds
Time After: 0.23865 seconds
Memory Before: 4,287.914 KB
Memory After: 4,288.125 KB
