Time Before: 0.01655 seconds
Time After: 0.02187 seconds
Time Taken: 0.00532 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02196 seconds
Time After: 0.02236 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02259 seconds
Time After: 0.02272 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02348 seconds
Time After: 0.02589 seconds
Time Taken: 0.00241 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02278 seconds
Time After: 0.02995 seconds
Time Taken: 0.00717 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03498 seconds
Time After: 0.03545 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03857 seconds
Time After: 0.03979 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03429 seconds
Time After: 0.04001 seconds
Time Taken: 0.00572 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07519 seconds
Time After: 0.07533 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.13393 seconds
Time After: 0.13531 seconds
Time Taken: 0.00138 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.13705587387085
Time Before: 0.16842 seconds
Time After: 0.16863 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.17491 seconds
Time After: 0.17640 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773333803, location = '/forums/private.php?do=newpm&explain=1&u=115961', badlocation = 1
Time Before: 0.20255 seconds
Time After: 0.20289 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.20135307312012 seconds with 9 queries, spending 0.0082018375396729 doing MySQL queries and 0.19315123558044 doing PHP things.
