Time Before: 0.02448 seconds
Time After: 0.02918 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02929 seconds
Time After: 0.02975 seconds
Time Before: 0.03002 seconds
Time After: 0.03019 seconds
Time Before: 0.03123 seconds
Time After: 0.03316 seconds
Time Taken: 0.00193 seconds
Time Before: 0.03027 seconds
Time After: 0.03729 seconds
Time Taken: 0.00702 seconds
Time Before: 0.04441 seconds
Time After: 0.04480 seconds
Time Before: 0.04715 seconds
Time After: 0.04838 seconds
Time Before: 0.04364 seconds
Time After: 0.04866 seconds
Time Taken: 0.00503 seconds
Time Before: 0.08658 seconds
Time After: 0.08676 seconds
Time Before: 0.10536 seconds
Time After: 0.10665 seconds
Time Before: 0.11485 seconds
Time After: 0.11502 seconds
Time Before: 0.11747 seconds
Time After: 0.11890 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115986' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.13595 seconds
Time After: 0.13625 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
