Time Before: 0.00150 seconds
Time After: 0.00207 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00216 seconds
Time After: 0.00254 seconds
Time Before: 0.00275 seconds
Time After: 0.00290 seconds
Time Before: 0.00372 seconds
Time After: 0.00664 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00295 seconds
Time After: 0.01000 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01167 seconds
Time After: 0.01208 seconds
Time Before: 0.01452 seconds
Time After: 0.01577 seconds
Time Before: 0.01114 seconds
Time After: 0.01602 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02167 seconds
Time After: 0.02186 seconds
Time Before: 0.02401 seconds
Time After: 0.02569 seconds
Time Taken: 0.00168 seconds
Time Before: 0.02979 seconds
Time After: 0.02997 seconds
Time Before: 0.03208 seconds
Time After: 0.03355 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=115997' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04774 seconds
Time After: 0.04812 seconds
