Time Before: 0.02978 seconds
Time After: 0.03712 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03723 seconds
Time After: 0.03776 seconds
Time Before: 0.03802 seconds
Time After: 0.03820 seconds
Time Before: 0.03901 seconds
Time After: 0.04129 seconds
Time Taken: 0.00228 seconds
Time Before: 0.03828 seconds
Time After: 0.04535 seconds
Time Taken: 0.00707 seconds
Time Before: 0.05619 seconds
Time After: 0.05659 seconds
Time Before: 0.05815 seconds
Time After: 0.05931 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05541 seconds
Time After: 0.05949 seconds
Time Taken: 0.00407 seconds
Time Before: 0.10183 seconds
Time After: 0.10200 seconds
Time Before: 0.28422 seconds
Time After: 0.28575 seconds
Time Taken: 0.00153 seconds
End call of global.php: 0.28786396980286
Time Before: 0.29359 seconds
Time After: 0.29375 seconds
Time Before: 0.29626 seconds
Time After: 0.29774 seconds
SET lastactivity = 1772715664, location = '/forums/private.php?do=newpm&explain=1&u=116002', badlocation = 1
Time Before: 0.31843 seconds
Time After: 0.31868 seconds
Page generated in 0.31714606285095 seconds with 9 queries, spending 0.0081369876861572 doing MySQL queries and 0.30900907516479 doing PHP things.
