Time Before: 0.00138 seconds
Time After: 0.00207 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00215 seconds
Time After: 0.00254 seconds
Time Before: 0.00279 seconds
Time After: 0.00290 seconds
Time Before: 0.00384 seconds
Time After: 0.00625 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00298 seconds
Time After: 0.01111 seconds
Time Taken: 0.00813 seconds
Time Before: 0.01378 seconds
Time After: 0.01419 seconds
Time Before: 0.01716 seconds
Time After: 0.01837 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01296 seconds
Time After: 0.01865 seconds
Time Taken: 0.00569 seconds
Memory After: 2,261.703 KB
Time Before: 0.02482 seconds
Time After: 0.02494 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02773 seconds
Time After: 0.02895 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03327 seconds
Time After: 0.03345 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03598 seconds
Time After: 0.03746 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116020', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05203 seconds
Time After: 0.05242 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
