Time Before: 0.01057 seconds
Time After: 0.01409 seconds
Time Taken: 0.00351 seconds
Time Before: 0.01417 seconds
Time After: 0.01467 seconds
Time Before: 0.01494 seconds
Time After: 0.01510 seconds
Time Before: 0.01600 seconds
Time After: 0.01865 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01518 seconds
Time After: 0.02237 seconds
Time Taken: 0.00720 seconds
Time Before: 0.02665 seconds
Time After: 0.02703 seconds
Time Before: 0.02952 seconds
Time After: 0.03071 seconds
Time Before: 0.02603 seconds
Time After: 0.03094 seconds
Time Taken: 0.00491 seconds
Time Before: 0.05311 seconds
Time After: 0.05327 seconds
Time Before: 0.06282 seconds
Time After: 0.06405 seconds
Time Before: 0.06876 seconds
Time After: 0.06892 seconds
Time Before: 0.07116 seconds
Time After: 0.07263 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116065' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.08847 seconds
Time After: 0.08874 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
