Time Before: 0.00403 seconds
Time After: 0.00562 seconds
Time Taken: 0.00159 seconds
Time Before: 0.00569 seconds
Time After: 0.00603 seconds
Time Before: 0.00620 seconds
Time After: 0.00633 seconds
Time Before: 0.00693 seconds
Time After: 0.00895 seconds
Time Taken: 0.00202 seconds
Time Before: 0.00638 seconds
Time After: 0.01238 seconds
Time Taken: 0.00600 seconds
Time Before: 0.01479 seconds
Time After: 0.01506 seconds
Time Before: 0.01633 seconds
Time After: 0.01751 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01422 seconds
Time After: 0.01770 seconds
Time Taken: 0.00347 seconds
Time Before: 0.02449 seconds
Time After: 0.02461 seconds
Time Before: 0.03033 seconds
Time After: 0.03153 seconds
Time Before: 0.03674 seconds
Time After: 0.03687 seconds
Time Before: 0.03981 seconds
Time After: 0.04123 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116095', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05964 seconds
Time After: 0.05992 seconds
