Time Before: 0.01143 seconds
Time After: 0.01468 seconds
Time Taken: 0.00325 seconds
Time Before: 0.01480 seconds
Time After: 0.01528 seconds
Time Before: 0.01554 seconds
Time After: 0.01569 seconds
Time Before: 0.01661 seconds
Time After: 0.01886 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01577 seconds
Time After: 0.02397 seconds
Time Taken: 0.00820 seconds
Time Before: 0.02777 seconds
Time After: 0.02822 seconds
Time Before: 0.03091 seconds
Time After: 0.03206 seconds
Time Taken: 0.00115 seconds
Time Before: 0.02698 seconds
Time After: 0.03228 seconds
Time Taken: 0.00530 seconds
Time Before: 0.04861 seconds
Time After: 0.04877 seconds
Time Before: 0.05969 seconds
Time After: 0.06094 seconds
End call of global.php: 0.063410043716431
Time Before: 0.06669 seconds
Time After: 0.06686 seconds
Time Before: 0.06934 seconds
Time After: 0.07082 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116105'
Time Before: 0.08956 seconds
Time After: 0.08983 seconds
Page generated in 0.088271856307983 seconds with 9 queries, spending 0.0077989101409912 doing MySQL queries and 0.080472946166992 doing PHP things.
