Time Before: 0.00177 seconds
Time After: 0.00238 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00248 seconds
Time After: 0.00296 seconds
Time Before: 0.00319 seconds
Time After: 0.00333 seconds
Time Before: 0.00423 seconds
Time After: 0.00688 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00340 seconds
Time After: 0.01222 seconds
Time Taken: 0.00882 seconds
Time Before: 0.01467 seconds
Time After: 0.01512 seconds
Time Before: 0.01866 seconds
Time After: 0.01986 seconds
Time Before: 0.01397 seconds
Time After: 0.02005 seconds
Time Taken: 0.00608 seconds
Time Before: 0.02553 seconds
Time After: 0.02568 seconds
Time Before: 0.02811 seconds
Time After: 0.02940 seconds
End call of global.php: 0.031991958618164
Time Before: 0.03339 seconds
Time After: 0.03354 seconds
Time Before: 0.03574 seconds
Time After: 0.03718 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116110', badlocation = 1
Time Before: 0.05120 seconds
Time After: 0.05149 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.05026388168335 seconds with 9 queries, spending 0.0082120895385742 doing MySQL queries and 0.042051792144775 doing PHP things.
