Time Before: 0.00138 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00246 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00268 seconds
Time After: 0.00278 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00341 seconds
Time After: 0.00582 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00283 seconds
Time After: 0.00915 seconds
Time Taken: 0.00632 seconds
Time Before: 0.01105 seconds
Time After: 0.01132 seconds
Time Before: 0.01378 seconds
Time After: 0.01508 seconds
Time Before: 0.01040 seconds
Time After: 0.01525 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02016 seconds
Time After: 0.02029 seconds
Time Before: 0.07701 seconds
Time After: 0.07827 seconds
End call of global.php: 0.080021142959595
Time Before: 0.08136 seconds
Time After: 0.08159 seconds
Time Before: 0.08429 seconds
Time After: 0.08574 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116123', badlocation = 1
Time Before: 0.09825 seconds
Time After: 0.09854 seconds
Page generated in 0.097321033477783 seconds with 9 queries, spending 0.0079967975616455 doing MySQL queries and 0.089324235916138 doing PHP things.
