Time Before: 0.00809 seconds
Time After: 0.01094 seconds
Time Taken: 0.00285 seconds
Time Before: 0.01101 seconds
Time After: 0.01146 seconds
Time Before: 0.01180 seconds
Time After: 0.01196 seconds
Time Before: 0.01268 seconds
Time After: 0.01524 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01201 seconds
Time After: 0.01980 seconds
Time Taken: 0.00779 seconds
Time Before: 0.02454 seconds
Time After: 0.02499 seconds
Time Before: 0.02756 seconds
Time After: 0.02876 seconds
Time Before: 0.02381 seconds
Time After: 0.02898 seconds
Time Taken: 0.00516 seconds
Time Before: 0.04584 seconds
Time After: 0.04599 seconds
Time Before: 0.05543 seconds
Time After: 0.05666 seconds
End call of global.php: 0.059154033660889
Time Before: 0.06245 seconds
Time After: 0.06264 seconds
Time Before: 0.06500 seconds
Time After: 0.06674 seconds
Time Taken: 0.00173 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116163'
Time Before: 0.08352 seconds
Time After: 0.08387 seconds
Page generated in 0.082376956939697 seconds with 9 queries, spending 0.0084657669067383 doing MySQL queries and 0.073911190032959 doing PHP things.
