Time Before: 0.00739 seconds
Time After: 0.01366 seconds
Time Taken: 0.00627 seconds
Time Before: 0.01377 seconds
Time After: 0.01419 seconds
Time Before: 0.01446 seconds
Time After: 0.01457 seconds
Time Before: 0.01534 seconds
Time After: 0.01743 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01462 seconds
Time After: 0.02112 seconds
Time Taken: 0.00650 seconds
Time Before: 0.02759 seconds
Time After: 0.02801 seconds
Time Before: 0.03097 seconds
Time After: 0.03227 seconds
Time Before: 0.02688 seconds
Time After: 0.03251 seconds
Time Taken: 0.00563 seconds
Time Before: 0.04958 seconds
Time After: 0.04972 seconds
Time Before: 0.06553 seconds
Time After: 0.06675 seconds
End call of global.php: 0.068871974945068
Time Before: 0.07548 seconds
Time After: 0.07562 seconds
Time Before: 0.07835 seconds
Time After: 0.07978 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116254'
Time Before: 0.09675 seconds
Time After: 0.09702 seconds
Page generated in 0.095750093460083 seconds with 9 queries, spending 0.0075576305389404 doing MySQL queries and 0.088192462921143 doing PHP things.
