Time Before: 0.01104 seconds
Time After: 0.01553 seconds
Time Taken: 0.00449 seconds
Time Before: 0.01564 seconds
Time After: 0.01607 seconds
Time Before: 0.01632 seconds
Time After: 0.01649 seconds
Time Before: 0.01730 seconds
Time After: 0.02013 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01658 seconds
Time After: 0.02458 seconds
Time Taken: 0.00799 seconds
Time Before: 0.02994 seconds
Time After: 0.03039 seconds
Time Before: 0.03307 seconds
Time After: 0.03426 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02925 seconds
Time After: 0.03447 seconds
Time Taken: 0.00522 seconds
Memory After: 2,261.820 KB
Time Before: 0.04541 seconds
Time After: 0.04556 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05509 seconds
Time After: 0.05637 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.059340000152588
Time Before: 0.06397 seconds
Time After: 0.06420 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06684 seconds
Time After: 0.06828 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789140325, location = '/forums/private.php?do=newpm&explain=1&u=116268'
Time Before: 0.08618 seconds
Time After: 0.08650 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.085114002227783 seconds with 9 queries, spending 0.0084981918334961 doing MySQL queries and 0.076615810394287 doing PHP things.
