Time Before: 0.00180 seconds
Time After: 0.00248 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00255 seconds
Time After: 0.00303 seconds
Time Before: 0.00324 seconds
Time After: 0.00339 seconds
Time Before: 0.00407 seconds
Time After: 0.00650 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00344 seconds
Time After: 0.01002 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01196 seconds
Time After: 0.01235 seconds
Time Before: 0.01493 seconds
Time After: 0.01612 seconds
Time Before: 0.01138 seconds
Time After: 0.01639 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02397 seconds
Time After: 0.02412 seconds
Time Before: 0.02695 seconds
Time After: 0.02821 seconds
End call of global.php: 0.029953002929688
Time Before: 0.03110 seconds
Time After: 0.03125 seconds
Time Before: 0.03329 seconds
Time After: 0.03475 seconds
SET lastactivity = 1785293568, location = '/forums/private.php?do=newpm&explain=1&u=116289'
Time Before: 0.04852 seconds
Time After: 0.04893 seconds
Page generated in 0.047603130340576 seconds with 9 queries, spending 0.0080578327178955 doing MySQL queries and 0.039545297622681 doing PHP things.
