Time Before: 0.01555 seconds
Time After: 0.01880 seconds
Time Taken: 0.00325 seconds
Time Before: 0.01890 seconds
Time After: 0.01936 seconds
Time Before: 0.01962 seconds
Time After: 0.01977 seconds
Time Before: 0.02057 seconds
Time After: 0.02303 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01985 seconds
Time After: 0.02745 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03389 seconds
Time After: 0.03428 seconds
Time Before: 0.03686 seconds
Time After: 0.03805 seconds
Time Before: 0.03311 seconds
Time After: 0.03825 seconds
Time Taken: 0.00514 seconds
Time Before: 0.06248 seconds
Time After: 0.06263 seconds
Time Before: 0.07477 seconds
Time After: 0.07603 seconds
Time Before: 0.08434 seconds
Time After: 0.08451 seconds
Time Before: 0.08755 seconds
Time After: 0.08898 seconds
UPDATE session SET lastactivity = 1785478970, location = '/forums/private.php?do=newpm&explain=1&u=116303', badlocation = 1 WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.10557 seconds
Time After: 0.10587 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
