Time Before: 0.00136 seconds
Time After: 0.00186 seconds
Time Before: 0.00194 seconds
Time After: 0.00246 seconds
Time Before: 0.00273 seconds
Time After: 0.00284 seconds
Time Before: 0.00352 seconds
Time After: 0.00610 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00289 seconds
Time After: 0.00970 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01216 seconds
Time After: 0.01258 seconds
Time Before: 0.01399 seconds
Time After: 0.01527 seconds
Time Before: 0.01137 seconds
Time After: 0.01544 seconds
Time Taken: 0.00407 seconds
Time Before: 0.02045 seconds
Time After: 0.02079 seconds
Time Before: 0.02266 seconds
Time After: 0.02394 seconds
Time Before: 0.02681 seconds
Time After: 0.02701 seconds
Time Before: 0.02896 seconds
Time After: 0.03130 seconds
Time Taken: 0.00233 seconds
UPDATE session SET lastactivity = 1788845761, location = '/forums/private.php?do=newpm&explain=1&u=116310' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04513 seconds
Time After: 0.04546 seconds
