Time Before: 0.00840 seconds
Time After: 0.01194 seconds
Time Taken: 0.00354 seconds
Time Before: 0.01206 seconds
Time After: 0.01248 seconds
Time Before: 0.01281 seconds
Time After: 0.01294 seconds
Time Before: 0.01377 seconds
Time After: 0.01697 seconds
Time Taken: 0.00319 seconds
Time Before: 0.01303 seconds
Time After: 0.02208 seconds
Time Taken: 0.00906 seconds
Time Before: 0.02613 seconds
Time After: 0.02634 seconds
Time Before: 0.02948 seconds
Time After: 0.03068 seconds
Time Before: 0.02533 seconds
Time After: 0.03095 seconds
Time Taken: 0.00561 seconds
Time Before: 0.04710 seconds
Time After: 0.04722 seconds
Time Before: 0.05576 seconds
Time After: 0.05701 seconds
Time Before: 0.06307 seconds
Time After: 0.06323 seconds
Time Before: 0.06558 seconds
Time After: 0.06702 seconds
UPDATE session SET lastactivity = 1783167472, location = '/forums/private.php?do=newpm&explain=1&u=116316', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.08457 seconds
Time After: 0.11126 seconds
Time Taken: 0.02668 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
