Time Before: 0.01708 seconds
Time After: 0.02351 seconds
Time Taken: 0.00643 seconds
Time Before: 0.02363 seconds
Time After: 0.02408 seconds
Time Before: 0.02434 seconds
Time After: 0.02447 seconds
Time Before: 0.02531 seconds
Time After: 0.02726 seconds
Time Taken: 0.00195 seconds
Time Before: 0.02455 seconds
Time After: 0.03108 seconds
Time Taken: 0.00654 seconds
Time Before: 0.04584 seconds
Time After: 0.04620 seconds
Time Before: 0.04770 seconds
Time After: 0.04894 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04505 seconds
Time After: 0.04920 seconds
Time Taken: 0.00415 seconds
Memory After: 2,261.820 KB
Time Before: 0.07978 seconds
Time After: 0.07990 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10515 seconds
Time After: 0.10641 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.10867094993591
Time Before: 0.11659 seconds
Time After: 0.11724 seconds
Time Taken: 0.00066 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11991 seconds
Time After: 0.12133 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789148016, location = '/forums/private.php?do=newpm&explain=1&u=116320', badlocation = 1
Time Before: 0.14543 seconds
Time After: 0.14576 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.14402294158936 seconds with 9 queries, spending 0.0079071521759033 doing MySQL queries and 0.13611578941345 doing PHP things.
