Time Before: 0.00931 seconds
Time After: 0.01095 seconds
Time Taken: 0.00164 seconds
Time Before: 0.01102 seconds
Time After: 0.01141 seconds
Time Before: 0.01160 seconds
Time After: 0.01174 seconds
Time Before: 0.01254 seconds
Time After: 0.01477 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01180 seconds
Time After: 0.01873 seconds
Time Taken: 0.00693 seconds
Time Before: 0.02385 seconds
Time After: 0.02428 seconds
Time Before: 0.02695 seconds
Time After: 0.02814 seconds
Time Before: 0.02310 seconds
Time After: 0.02838 seconds
Time Taken: 0.00529 seconds
Time Before: 0.04490 seconds
Time After: 0.04503 seconds
Time Before: 0.05378 seconds
Time After: 0.05509 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.056895017623901
Time Before: 0.06378 seconds
Time After: 0.06391 seconds
Time Before: 0.06696 seconds
Time After: 0.06839 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=116330', badlocation = 1
Time Before: 0.08424 seconds
Time After: 0.08457 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.08328104019165 seconds with 9 queries, spending 0.0077040195465088 doing MySQL queries and 0.075577020645142 doing PHP things.
