Time Before: 0.01097 seconds
Time After: 0.01804 seconds
Time Taken: 0.00707 seconds
Time Before: 0.01813 seconds
Time After: 0.01855 seconds
Time Before: 0.01877 seconds
Time After: 0.01890 seconds
Time Before: 0.01975 seconds
Time After: 0.02212 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01897 seconds
Time After: 0.02661 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03546 seconds
Time After: 0.03588 seconds
Time Before: 0.03898 seconds
Time After: 0.04407 seconds
Time Taken: 0.00509 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03484 seconds
Time After: 0.04426 seconds
Time Taken: 0.00943 seconds
Memory After: 2,261.703 KB
Time Before: 0.06280 seconds
Time After: 0.06294 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07891 seconds
Time After: 0.08021 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08755 seconds
Time After: 0.08769 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09029 seconds
Time After: 0.09267 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116386' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11048 seconds
Time After: 0.11096 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
