Time Before: 0.03357 seconds
Time After: 0.04313 seconds
Time Taken: 0.00956 seconds
Time Before: 0.04324 seconds
Time After: 0.04374 seconds
Time Before: 0.04398 seconds
Time After: 0.04410 seconds
Time Before: 0.04490 seconds
Time After: 0.04769 seconds
Time Taken: 0.00279 seconds
Time Before: 0.04415 seconds
Time After: 0.05158 seconds
Time Taken: 0.00743 seconds
Time Before: 0.06105 seconds
Time After: 0.06148 seconds
Time Before: 0.06420 seconds
Time After: 0.06570 seconds
Time Taken: 0.00150 seconds
Time Before: 0.06020 seconds
Time After: 0.06592 seconds
Time Taken: 0.00572 seconds
Time Before: 0.12159 seconds
Time After: 0.12178 seconds
Time Before: 0.14042 seconds
Time After: 0.14162 seconds
Time Before: 0.14989 seconds
Time After: 0.15005 seconds
Time Before: 0.15293 seconds
Time After: 0.15443 seconds
UPDATE session SET lastactivity = 1785276096, location = '/forums/private.php?do=newpm&explain=1&u=11639' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.17701 seconds
Time After: 0.17728 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
