Time Before: 0.01423 seconds
Time After: 0.01591 seconds
Time Taken: 0.00168 seconds
Time Before: 0.01599 seconds
Time After: 0.01638 seconds
Time Before: 0.01663 seconds
Time After: 0.01675 seconds
Time Before: 0.01740 seconds
Time After: 0.01975 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01680 seconds
Time After: 0.02323 seconds
Time Taken: 0.00644 seconds
Time Before: 0.02731 seconds
Time After: 0.02774 seconds
Time Before: 0.02971 seconds
Time After: 0.03094 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02657 seconds
Time After: 0.03115 seconds
Time Taken: 0.00458 seconds
Memory After: 2,261.703 KB
Time Before: 0.05545 seconds
Time After: 0.05557 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.74807 seconds
Time After: 0.74985 seconds
Time Taken: 0.00179 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.76188 seconds
Time After: 0.76205 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.76527 seconds
Time After: 0.76695 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=116397' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.78503 seconds
Time After: 0.79968 seconds
Time Taken: 0.01465 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
