Time Before: 0.00152 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00245 seconds
Time Before: 0.00270 seconds
Time After: 0.00286 seconds
Time Before: 0.00354 seconds
Time After: 0.00630 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00292 seconds
Time After: 0.01134 seconds
Time Taken: 0.00843 seconds
Time Before: 0.01338 seconds
Time After: 0.01379 seconds
Time Before: 0.01681 seconds
Time After: 0.01802 seconds
Time Before: 0.01281 seconds
Time After: 0.01828 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02355 seconds
Time After: 0.02369 seconds
Time Before: 0.02612 seconds
Time After: 0.02735 seconds
Time Before: 0.03065 seconds
Time After: 0.03080 seconds
Time Before: 0.03291 seconds
Time After: 0.03439 seconds
UPDATE session SET lastactivity = 1784817739, location = '/forums/private.php?do=newpm&explain=1&u=116417' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04805 seconds
Time After: 0.04835 seconds
